跳转到主内容
加入维修社区 - 创建账户
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
My ipad is disabled how can I enable it without a computer
How do i enable my disabled apple ipad2 without computer or itunes
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 134
34条评论
What does the screen say?
完成的
Disabled try in20 min
完成的
I have the exact same problem
完成的
Ipad disabled connect to Itunes
完成的
iPad disabled connected to iTunes
完成的
显示更多的29条评论
添加一条评论
3个答案
已选择的解决方案
There is no way to enable a disabled iPad without a computer. If you can use a friend or family members internet enabled device and can access www.icloud.com/find it is possible to remotely erase your device by following the instructions below.
The following instructions are from Apple's Support Website
If you set up Find My iPhone on your iOS device or Mac, you can use iCloud to erase and restore it.
1. From another device, go to icloud.com/find.
2. If prompted, sign in with your Apple ID.
3. Click All Devices at the top of your browser window.
4. Select the device you want to erase.
5. Click Erase [device] to erase your device and its passcode.
6. Now you can either restore from a backup or set up as new.
If your device isn't connected to a Wi-Fi or cellular network, you can't erase it with Find My iPhone.
这个答案有帮助吗?
得分 44
15条评论:
I locked myself out of ipad2 did not sync nor did get to set up id quite yet
完成的
what if i did not sigh up to i cloud on this ipad
完成的
If you no have computer, and the iPad was locked, you can use Find My iPhone in another iPhone, but it's better to backup your iPhone first of all, and you from Find My iPhone, you can erase your iPad, so that you can unlock iPad without restore . Then restore from backup.
完成的
will this erase the iPads data?
完成的
Yes it will.
完成的
显示更多的10条评论
添加一条评论
there is no way to do that as stated by @dylanfaraone above.... you may follow his instruction.
or find PC with itunes
这个答案有帮助吗?
得分 6
添加一条评论
If you have an old backup then you can restore your backup then you got an option to insert a passcode for the final time.
这个答案有帮助吗?
得分 0
1条评论:
@thegsmsolution can't restore from backup "without a computer" . This Question is 7 years old and the OP is long gone.
完成的
添加一条评论
添加你的答案
wednesday 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 114
总计 310,311
