HDD, RAM Change / replace
Hi!
I have bought a 2011 imac mid today.
I have tools to replace the hdd, ram and replace the dvd rom with an ssd.
But I have some questions:
1. I can use any type of HDD to replace the HDD? So I can put in it WD Green 2TB hdd?
2. I can use any type of SSD? (I am planning to use a 250 GB samsung ssd)
3. iMac using simple notebook memory? Or its a special ram type?
4. Bluetooth chip is integrated on the motherboard or Is there any way to replace with a bluetooth 4.0 ? Or is there any way to use bt 4.0 on this 2011 mid 21,5" iMac?
Thanks!
Update (11/13/2015)
But I can use 4x8 gb 1333 MHz PC3-10600 DDR3 SO-DIMMs RAMs, right?
So the mark is nevermind? samsung / kingston?
I have seen some videos where guys replaced the BT card in 2011 macbook pro, and after the replace they can use the handoff and everything, which is avelable just in the new mac models.
And thats why I want to upgrade it too.. :)
And another thing... I have seen a video, where the video creator used the same heat detector from the old HDD, is it possible? So if i remove the old heat detector, and put it on the new one, it will works? So i dont need special cable to use it?
And Where can I buy a new sata cable, to connect the SSD? Beucase I have seen in the videos the power cable is different on the motherboard, but the data cable is the same like in a simple PC.
I hope you will answer!
Thanks.
6条评论
The brand of RAM is less important than the specs of the RAM. You should use a matched pair if you can.
由 Dan 完成的
BlueTooth on a MacBook Pro's is not the same in iMac's! As I stated you'll need to use a Dongle. Review this: Continuity Activation Tool for HandOff. I don't recommend doing this internally as you will likely damage things (besides being more costly)
由 Dan 完成的
Different series of iMac's use different setups. This series requires the adapter cable.
由 Dan 完成的
Here is what you'll need for the SSD: iMac Intel 21.5" Mid 2011 Dual Hard Drive Kit - Complete Kit
由 Dan 完成的
And what about usb BT adapters? Its not compatible with mac?
由 Richard 完成的
显示更多的1条评论
