跳转到主内容
Sony CFD-S05 CD Radio Cassette Player was released in 2010, and has the CD-R/RW playback function.
25 个问题 查看全部
Sound not coming out of radio.
My sony is not making a sound except a faint one on one channel...I HAD HEARD THERE IS SOMETHING YOU CAN SPRAY IN THE BOARD INSIDE THAT HELPS THE CONNECTIVITY OF ALL CONNECTIONS..IF SO HOW CAN I do this myself..what chemical spray do I buy..? ( hit the caps accidentally, sorry )
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
visayan95 "faint one on one channel " sounds more like an issue with the amplifier section on your board. You do want to take it apart and check the power amp IC. The spray you might be thinking off is contact spray. That is commonly used to spray to pot (volume button) etc. Your symptoms sound way beyond bad contacts. Use these guides to work on it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
visayan95 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 2,101
