跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
问题已关闭
Can I replace the CD Drive on the white iMac?
I recently purchase a 2006 White Imac for $25.00, the Imac is beautiful and still working pretty good, but was wondering if there was a way to give it a little speed upgrade using an SSD; I am also interested of installing a second drive where the current Cd drive is located...is it possible? Anyone done such upgrade?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your problem is backward compatibility to SATA I 1.5GHz per second.
I would go with a 3.5" hybrid drive. This one will work for you:
Seagate 1.0TB Desktop SSHD Solid State Hybrid Drive
ST1000DX001
This drive should be large enough so that you have no need to change out the optical drive.
1 TB SSD Hybrid 3.5" Hard Drive
1 TB SSD Hybrid 3.5" Hard Drive图片
产品
$109.99
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 59
