跳转到主内容
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
66 个问题 查看全部
Why is my computer on but I can not see anything?
The computer is on but i can not see anything on the screen unless you hold a flashlight to it. It works perfectly fine when it is hooked up to a monitor . This started when I changed my screen after it cracked . After I changed it with a brand new LCD it never worked. I do not understand what is going on please help I do not want to get new laptop unless I have to because this one works just fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ashia Martin, sounds like a backlight inverter issues. The inverter for the back light is below the screen within the housing for the screen. If you replaced the screen assembly complete with housing you should contact the supplier since it is possible that you have a bad inverter. If you just replaced the LCD, you may have a failed backlight inverter. Of course, you do want to make sure that you plugged everything in as well.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ashia Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 78
