跳转到主内容
加入维修社区 - 创建账户
XV20 系列 Toyota Camry 是 Toyota 第 6 代 Camry 轿车。
Why won't my car start?
My 1999 Toyota Camry won't start, sometimes it will if I tap on the starter and press on the gas as I turn the key. Could my starter need replaced or my fuel pump?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Kaitie Richards does it make any noise when you try to start it? Does the engine turn over? When you turn your headlights on and try to start your Camry, do the lights go dim? What engine size does your Camry have and is it automatic or standard transmission?
完成的
添加一条评论
5个答案
已选择的解决方案
This may be too late but...
I had this problem with my 1999 Camry and it turned out to be a bad starter motor. At first tapping on it would allow me to start the car but after a while it'd take more and more until at one point it just stopped starting period.
If this turns out to be your problem it's a pretty cheap and simple fix to do yourself for the most part: pick up a starter at O'Reillys , pop the old one out and the new one in. It was pretty straightforward so I didn't use a guide or video but this video seems to be a good start.
这个答案有帮助吗?
得分 2
添加一条评论
never pump the gas pedal on a fuel injected car when trying to start it
这个答案有帮助吗?
得分 2
添加一条评论
If tapping on the starter gets it going then yes you need a new starter heres how to do it
https://www.youtube.com/watch?v=YOAm-qtI...
这个答案有帮助吗?
得分 1
添加一条评论
Turn the key to the "on" position without trying to start it, you should hear the fuel pump run for a few seconds then stop. Also you could pick up a cheap fuel pressure tester at an auto parts store and attach it to the valve on your fuel rail to get a true reading.
Do you have a multimeter? Check the battery to make sure it is reading at least 12V DC, the value should go up to about 13-14V once the engine is started, that lets you know the alternator is charging up the battery correctly.
When you say you "tap on the starter" are you crawling under the car and hitting the starter motor/solenoid? If you are and it works, it a good sign that the starter solenoid and/or starter is bad and sticking.
这个答案有帮助吗?
得分 0
添加一条评论
Everything in the car turns on and when I go to turn it on it makes a clicking sound when I try to turn it on but it won’t start
这个答案有帮助吗?
得分 0
1条评论:
juan zuniga - may want to make sure the battery positive and ground cables are mounted securely on the battery.
完成的
添加一条评论
添加你的答案
Kaitie Richards 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 43
总计 7,174
