跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
449 个问题 查看全部
问题已关闭
digitizer resistor missing from bottom
I am replacing the digitizer/lcd and have lost the small resistor that solders to the bottom in my iPad Air 2 A1567. need help.
Update (11/04/2015)
Attached is the pictures. the first shows the new digitizer without the resistor. The second on the top is without resistor and the bottom is with resistor from a repair video. I also need to know if this ipad should work without this resistor. After putting this back together it will not power on at all. I checked the battery and it is fully charged. I tried all the reset procedures on the web but nothing works. Thanks for any help.
Update (11/04/2015)
I don't know how to add pictures
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Post an image of your logic board and mark the area where the component is missing. There is no way to identify it by your description alone
完成的
Pictures aren't clear enough, I'm not sure what you're describing. Tell us more about the history of the device and problem.
Jessa
完成的
添加一条评论
2个答案
Didn't see the pics.
这个答案有帮助吗?
得分 0
5条评论:
I have added pics
完成的
That is the port for one of the hall effect sensors to detect the smart cover.
完成的
will the unit work without the sensor.
完成的
Yes, however you lose smart cover auto lock. And also I recommend taping the contact pads over to prevent shorting/
完成的
Thanks so there is something else wrong since it will not come on at all, (sigh) my customer is going to be very upset but I am at a loss as what else to do.
完成的
添加一条评论
Small IC left of home button pretty much like everyone else said above. but better make that ipad air 2 come alive again first!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 237
