跳转到主内容
加入维修社区 - 创建账户
iPad Air 2 于 2014 年 10 月 16 日发布,是 iPad Air 的更轻薄继任机型。
Small IC left of home button
Hi. I have been repairing an ipad air 2 and noticed that my replacement bonded digitizer and screen assembly came with a small flap with 4 solder points on it. Upon inspection of the broken part it became apparent that a small printed circuit was soldered to the flap with an IC on it. my guess it has something to do with cover to sleep the pad, can anyone confirm this please. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Does your unit work without the small ic?
由完成的
添加一条评论
3个答案
最有帮助的答案
Yes, those components are necessary for the smart cover to work. If the part that you received doesn't have them, then you should return them for an exchange or purchase from another supplier.
这个答案有帮助吗?
得分 1
2条评论:
Or - like I just did - remove the IC from the old screen by hotair(I used 300C for 2 sec) and resolder it to the pads on the new screen.
由完成的
@ anders.. did it work?
由完成的
添加一条评论
Yes that is one of the hall effect sensor for the smart cover.
这个答案有帮助吗?
得分 1
添加一条评论
Has Anyone found a supplier for these chips?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
refurbight 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 13
过去 30 天: 24
总计 1,099
