跳转到主内容
加入维修社区 - 创建账户
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Correct name for Connector
Need to replace the Connector on the main Board that connects the Home Key flex to it. But need the correct name for it so I can start the search. Can anyone help with that please. Someone may even know where I could get one or three ! (fingers crossed)
This Connector is off a different Samsung but it is the exact same one as on the S3
I have managed to De-solder one using low heat and lots of time but in doing so can't remove it without damaging the connector itself..... but the board is left with no damage at all ........................................ little step !
On the Board the connector is bottom left of SWEP GRG28 antenna switch module (Thanks oldturkey3 & Jimfixer)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This is a tear down guide it labels parts as it shows you proper tear down . Im sure you'll find what you need here.
Samsung Galaxy S5 Teardown
As well if you click on Samsung Galaxy S5 in the box in the right hand corner it will take you to an information page with tear down of various parts and were to by parts
这个答案有帮助吗?
得分 2
添加一条评论
accmpmer, it would help if you can post an image of the connector that you are looking for with your question. Right now, and going by your description only, the connector should be Samsung part number 3711-007172 and is available at places like this as well as many others. To post images with your question, use this guide.
这个答案有帮助吗?
得分 1
3条评论:
I thank you for this suggestion and yes I will do this asap
完成的
Thank you for adding the images. Yes, that is a Samsung 3711-007172 available right here as well as many others.
完成的
Fantastic oldturkey03 Your bloods worth bottling!
完成的
添加一条评论
添加你的答案
Charlie Clemett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 272
