跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for all revisions of the Apple TV media player and streaming box.
Apple TV IR sensor
Where can I buy and how can I replace the IR sensor of an Apple TV?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Check the voltage on the CR2032 in the remote first. Once these get to the point they only have 2V left, most CR2032 batteries are no longer usable in applicationa like a remote. Should that not work, try a new remote - if this doesn't help the Apple TV has a problem.
Resetting the Apple TV will not help a hardware fault, so don't bother - you will not fix anything that way so your next best step is to replace the board - you will probably need a donor for this due to the cost to ship such a part, but it is possible to do a module replacement for this component.
With the 2nd generation-present Apple TV, you will need to repair the board as the sensor is integrated and is not modular.
这个答案有帮助吗?
得分 3
2条评论:
why do you take out the logic board first?
完成的
I fixed it from what it was
完成的
添加一条评论
添加你的答案
Cassius 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,228
