Monitor Making High Pitched Sounds
Why is my monitor making high pitched sounds?
Monitor out of range
The monitor’s may be too far apart from each other. Try to get closer to the other monitor. If this does not help, try to adjust the sensitivity level.
Need to adjust sensitivity level
Try to adjust the sensitivity level to a lower level to avoid audio feedback.
Monitors may be too close ¶
The monitors have to be more than three feet away from each other. Try backing up from the monitor to get rid of noise. If this does not work, try adjusting the sensitivity level.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 37
总计 1,134
