跳转到主内容
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
80 个问题 查看全部
O/D light blinking after 20 minutes
The O/D light on my 2004 Ranger with a 5R55E transmission is blinking after about 20 minutes of driving. The code is P0735, "gear 5 incorrect ratio." It shifts fine before the light blinks. Even after it blinks, it drives fine in gear 5, but once the light blinks, shifting is abnormal. Might changing the TR Sensor help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Bob DeCamp, this is going to be tough on. This could be as simple as
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
after that you could be running into major issues. It could be a valve body problem as well as the front (OD) servo or a bad OD band (unlikely since your trouble start after some driving). I'd start with simple (inexpensive) to complicated (expensive) as well as a good manual
这个答案有帮助吗?
得分 1
1条评论:
Fluid is clean and at correct level. Can front (OD) servo be changed without removing tranny? What about the question of the TR Sensor?
完成的
添加一条评论
Can low transmission fluid cause the od off light to come on
这个答案有帮助吗?
得分 0
1条评论:
Low levels can cause the light to come on . Dirty fluid can also cause this problem . Fluid that's loosing its viscosity can also do be a cause
完成的
添加一条评论
Would a shift kit fix this issue? I'm having the exact same problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bob DeCamp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 38
过去 30 天: 172
总计 20,215
