跳转到主内容
加入维修社区 - 创建账户
Monster DNA 耳机发布于 2012 年,型号为 MH DNA ON WHT CA WW。
Why is one of the speakers working?
Whenever I use this device, I have found out that there is a problem with speaker because I think that the sound quality seems poor. What can I do in order to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
My daughter had the same problem. Only one speaker working.
It turned out that the connector cable (the cable with the TRRS plugs on both sides; which transmits the signals from the audio source to the headphones) had a broken wire.
I found out by checking the conductivity of the cables with an ohmmeter, probing sequentially the corresponding segments of the TRRS connectors (if you don't know what a TRRS connector is, check on Wikipedia under "phone connector (audio)").
The cable is very flexible and is coated with a very soft rubber-like plastic. It invites rolling up the cable to a tight coil, or playing with it and bending it strongly while listening to music. This is how one of the wires may have broken.
So, before you dissassemble the headphones (and possibly damage them in the process), first check the cable leading to the headphones.
这个答案有帮助吗?
得分 2
添加一条评论
In order to solve this problem, you should check to see if anything is blocking the speaker. If that is not the case, then there may be a loose internal wire or the speaker may need to be replaced.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mesfer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 3,040
