跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Why won't my iPod hold a charge or sync?
My iPod worked perfectly for years...then I dropped it. It broke in half at the seam. I squished it back together and it worked fine. This happened about 4 times. Then I dropped it again. It split in half and this time a little piece of gray plastic fell out. I shoved it where I thought it should go and closed it back up. Only this time it didn't work. The words and picture on the screen were broken up and the blacklight dimmmed then went out. I thought it was gone for good until I got home and plugged it into my wall charger and it booted back up like nothing was wrong. But when I unplugged it everything died. When I plug into the computer it says "very low battery. please wait." But never charges or syncs.
Is the battery just blown or is it a more serious problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
It also works just fine when it's plugged into my car charger/player.
完成的
添加一条评论
2个答案
已选择的解决方案
Just to answer this old question. If it works with it plugged in but does not charge, or quits working when unplugged, replace the battery. Start with the obvious things first, then look for the more complicated and expensive, like a logic board.
这个答案有帮助吗?
得分 1
添加一条评论
I would say is the same as this issue: usb device not recognized when plugged into computer
I'm betting for the logic board... but not a 100% sure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Esther Hamilton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,574
