跳转到主内容
Repair and troubleshooting guides for the DeWalt DW106, a discontinued 3/8" variable speed reversing (VSR) drill with a keyless chuck.
Dropped Drill no response from trigger.
After 8 years of light use I dropped my Dewalt DW106 3/8 in VSR drill. 8 feet to a wooden deck. Since then it is dead. Opening it I see no loose connections. The motor turns freely by hand. The power cord is not frayed at any point. There is no smell or visible evidence of an electrical short inside the plastic shell. Have you any idea what part would be most likely to fail as the result of such a short drop?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Tried bypassing the switch to see if it will run without it?
完成的
添加一条评论
2个答案
已选择的解决方案
Hy
Maybe, like odlturkey03 wrote, the Power Switch itself ist damaged.
Try tu bypass the switch and see if it works.
这个答案有帮助吗?
得分 1
添加一条评论
control all the wire connectors start from powercable > (supression coils) carbon brushes and their springs) the switch + (L+R ) and the electric field .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
supthehoop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 943
