跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
F:01 error code when trying to wash clothes
What does F:01 error code mean?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Mac Jones, F01 is the code for a failed main relay power control board. If you remove the board, take a look and see if you have any obvious damage which might be repairable. Take a look at the wiring as well as the components and connectors, check for corrosion.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mac Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,353
