跳转到主内容
加入维修社区 - 创建账户
A1418 | EMC 2889 | 2015 年末款 | 1.6 GHz 双核 Intel Core i5 或 2.8 GHz 四核 Intel Core i5。发布日期:2015 年 10 月 13 日。
replace hdd with ssd...?
is it possible to exchange the internal hdd with a proper ssd?
i know the RAM is not, which is a pitty...
thanks for the answers!
mijoto
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Given this is such a new system why don't you buy the system with the larger SSD already installed (PCIe vs SATA)? 3.1 GHz 21.5" iMac with 512 GB flash.
Then if you want to add in a better hard drive or a second SSD. Thats what I would do.
That way you get the benefits of ultra fast M.2 PCIe interface of the SSD blade drive which is now using NVM Express and then you can use the slower SATA III (6.0 Gb/s) for your second drive.
这个答案有帮助吗?
得分 3
添加一条评论
As a quick answer, if you already own your iMac, yes you can swap the sluggish HD with a 6.0 Gb/s SSD.
It'll be waaaay faster !
这个答案有帮助吗?
得分 1
添加一条评论
The read and write speeds of an SSD are faster than a standard HD but not near the transfer rating of SATA III so using PCIe won't gain speed. Certainly buying a new computer will speed up everything if that is what you need.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mijoto 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 3,240
