跳转到主内容
加入维修社区 - 创建账户
Optical Drive won't burn disks something about calibrating the Laser?
I just bought this MBP and the first time i tried burning a disk ( CD - Memorex and Sony ) using finder it didn't work it claimed failure " to calibrate laser " for the type of media. i tried using 8x speed and 24x speed. after about ten tries i was able to burn two of the disks that i needed for a client. i haven't tried using the generic boot up option yet. First wanted to check what other users have done about this problem.
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
If the laptop is new, take it to Apple.
If you've had it for a few years, the drive can be replaced. You will need this part. If you're choosing between the 6X and 8X drive, you're better off getting the 8X since it generally isn't much more expensive. The guide to install the drive can be found here.
Replace a broken or damaged 8x SuperDrive for MacBook or MacBook Pro 15" with this part.图片
产品
MacBook/MacBook Pro 15" 8x SuperDrive
$69.99
这个答案有帮助吗?
得分 1
2条评论:
oops , i guess i wasn't specific enough , i bought it from a friend, it was one of the first gen. MBP the apple care is expired.
完成的
+ good
完成的
添加一条评论
添加你的答案
jimmy jazz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,545
