screen broke from the inside can I fix it
My tablet got crack from the inside can it be fixed. Some one please help
patty abarca, from what you are describing it sounds like a broken LCD but intact digitizer. It will help if you post some images of what you see with your question. Use this guide to do so. The LCD's are readily available at places like this and many others. There are no repair guides out, so I would suggest that you check check on here as well as on here for similarities. When you do decide to work on it, [URL|make] create a guide so we can all learn from it.
指南
难度:
非常容易
2 - 5 minutes
指南
难度:
困难
30 - 40 minutes
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 377
2条评论
does the tablet still work?
Power on can you see the screen and does it respond to touch
由 Jimfixer 完成的
It turns on but all u can see is liqud. No it does not respond to touch
由 Lewis Jones 完成的
