跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
799 个问题 查看全部
问题已关闭
Changed iPod battery still loses its charge overnight?
I recently changed my Ipod battery as the old one was not holding a charge. The new battery works fine but it loses its charge overnight. The new battery is a 450mAh one, should I get a new 580mAh battery to see if it will solve the problem or is the problem the logicboard??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
binod5098, the larger battery will also loose some of it's charge, it will just take longer to be fully depleted this is a case where the mAh wont matter. Check your settings to see where you are losing the charge. Backlight and hard drive etc. are tough on power
这个答案有帮助吗?
得分 1
4条评论:
Thanks, do you think changing the hard drive to a SD card (Reader) drive will have any effect on the problem?
完成的
The power consumption will definitely be less:-)
完成的
Nice, I might give that a try. Is there a limit to how big the SD card size I could use, as the Ipod is a 30gb.
完成的
take a look on here and on here as well
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 86
