跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
The non-magenetic screw instruction is wrong
Three times, I’ve tried to correct the non-ferrous/non-magnetic screw instructions for both the 5 and 5s.
iPhone 5s Home键更换
Each time, the correction was denied by iFixit staff.
Why? It’s obvious to anyone who has fixed a 5 or 5s that the instructions are wrong, and worse, the instructions that are there on the site will damage the device and screw with the magnetometer when reassembled.
The non-magnetic screw is longer and in the upper right, not shorter or in the lower left.
Why were the corrections denied and why three times?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
cs, that may have to do with you not having enough reputation points to make those changes. Looks like you will need 30,000 for that. You may have more luck contacting the ifixit staff directly on here or leave a comment/question on here. It is more frequently visited by the ifixit staff.
这个答案有帮助吗?
得分 1
1条评论:
That or get to posting
完成的
添加一条评论
最有帮助的答案
You're right, it's wrong. I have no idea
这个答案有帮助吗?
得分 2
添加一条评论
They're wrong about a lot of things. I just use the guides to have some idea about the internal layout, after that you're on your own.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Drtofu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 140
