跳转到主内容
加入维修社区 - 创建账户
2007年由惠普(HP)生产的商用台式电脑。获“绿色PC”认证 / 英特尔酷睿2双核处理器
will it work with an intel slb6b processor?
have 2 gb of ram 159gb hdd wirh a intel dual core 1.80 processor and it hangs or stalls when using propresenter 5
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
the intel processor is 2.66 ghz / 6m /1333 /05A.core 2 quad core
完成的
What are the model specifications on your current processor? You can check the socket of the compare those specs with those Intel® Core™2 Quad Processor Q9400S against what you have as a starting/reference point.
完成的
Most likely, but still possibly not. The motherboard may not support the specific processor, but it is worth a try. The socket is the same. But you may need to install a new heatsink for the new CPU. It has a higher Thermal Design Power.
Check this link if you need help installing a CPU:
HP rp5700 中央处理器 (CPU) 更换
完成的
添加一条评论
1个答案
The rp5700 only supports CPUs with a 1066 MHz FSB. The Q9400 (SLB6B) has a 1333 MHz FSB. The fastest CPU supported is a Core 2 Duo E7400.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aeryn TwoFeathers 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 14
总计 611
