跳转到主内容
Released fall 2013, the Z30 is a touchscreen smartphone by BlackBerry.
21 个问题 查看全部
Wifi chip /IC location on Blackberry Z30
I need to know where exactly the wifi chip/ic on my z30 motherboard is located. My wifi sometimes detects signals , sometimes not . If is detects signals , sometimes it connects sometimes not . I think a simple heating up the wifi chip might fix my problem. Please some 1 help me tx.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Nav J, you will have to provide us with a good image of your circuit board. U1000 and the rest of the WiFi circuitry are under the EMI shield just adjacent to your micros Sd and SIM card slot
完成的
Sorry I was out of town . I will post close up pic of the motherboard . Please point of where is the wifi IC located . Also if you have any idea of wifi antenna plz let me know
http://i68.tinypic.com/2j1jz4n.jpg
完成的
添加一条评论
2个答案
最有帮助的答案
Nav J, from what it looks like on the schematic the Wifi chip is U1000. It is under the EMI shield marked on the attached image
这个答案有帮助吗?
得分 2
添加一条评论
Hi I have removed the shield , please confirm whether the shiny IC is wifi IC or not. Also on the another picture you may notice that one small connector is broken . Can you please tell me what is the use of that connector.?
这个答案有帮助吗?
得分 0
1条评论:
what you managed to do? I am in the same situation. No wifi but great 4G signal
You repaired it? I need to know if a buy another phone cheaper and replace the mother board
完成的
添加一条评论
添加你的答案
Nav J 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 18
总计 1,056
