跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Missing solder pad on Touch screen connector iPad mini 2
Hi guys,
We have a problem.
A customer brought an iPad 2 mini. I disassembled ipad, and I realized the touch screen connector was damaged. I removed the connector with solder iron, but one of the solder pad are missing.
what is the solution ?
thanks
Tibor
picture:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
This is all wrong !!! The missing pad is 5th pad !! 5 NC - no connection !!
Yellow selection is pad 6,
oldturkey :D
这个答案有帮助吗?
得分 2
7条评论:
@fixlab excellent job in finding this. Amazingly enough it took a year for somebody to catch this error. I did correct the original answer.
完成的
No problem ;)
完成的
@fixlab I have the same problem. The pads number 5, 15, and 17 are missing. Colud you help me with the schematic picture? Where could I connect the missing pads? Thanks!
完成的
gabor, pin 5 is nc, pin 15 is ground and 17 you can connect to the large cap to the left side of the connector. on the right side of the cap
完成的
Thank you daniel!
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
Iphoneszerviz Szeged, correction. That is contact #5 of J1700. It does not need anything. NC no connection
这个答案有帮助吗?
得分 6
6条评论:
Very useful, Thank you!
完成的
By placing a jumper from the cable to the board?
完成的
thank you old turkey, :)
完成的
@oldturkey03 extremely grateful!
完成的
@iphoneszerviz, did you manage to repair this? Can u post a pic or explain a little what you had to do exactly? We are facing a similar prblem ourselves with the exact same pad ripped off during a connector replacement
完成的
显示更多的1条评论
添加一条评论
try to use best or recommended rework tools when you touching high tech logic boards. Here i can see one path Path damaged on your logic board.
you have two options,
1) Change the new logic board
2) Path modification : check the path destination and you may have to connect them physically
All the best!
这个答案有帮助吗?
得分 2
3条评论:
circuity diagram available this iPad?
完成的
creativeelectron (http://creativeelectron.com/) seeking your support to find path of 8th contact - TP
完成的
jessabethany, seeking your support as well
完成的
添加一条评论
添加你的答案
Iphoneszerviz Szeged 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 4,736
