跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 5 (又称 Note5) 是一款配备手写笔的平板手机,由三星制造,于 2015 年 8 月发布。
Rear camera glass replacement
My rear camera glass has shattered. I was wondering if I could find a replacement piece or workaround for this issue. I'm completely comfortable with tearing down the phone, but would very much prefer not to have to do so. If an s6 lens would fit, that's fine. Any solutions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
7条评论
Hi, I have the same problem, what is the cost to supply & fit the rear glass?
由完成的
It cost me under $20 for the parts, and about 15 minutes of time. Keep in mind, that's just the glass, not the sensor.
由完成的
where do I buy the parts to fix the glass? can somebody please direct me. I just need to fix the glass on the cover, the square one
由完成的
Here is Samsung Galaxy Note 5 Camera Glass Lens: http://www.witrigs.com/oem-camera-lens-f... , hope it can help you.
由完成的
I bought a oppo neo 7 mobile bt rear camera glasses was broken where is available and cost of spears
由完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
There are no note 5 camera lenses available at the moment. I damaged my rear camera glass and the camera itself.
I replaced the camera in the device and used an s6 glass lens for the present time until parts are available. It works fine albeit the lens is noticeably too small.
Merely pry your old shattered lens off as it is held on by adhesive and stick the new one on! Hopefully this helps anyone who was in a similar predicament as I was.
The rear camera module is readily available online if you happened to have damaged it.
这个答案有帮助吗?
得分 1
2条评论:
where do I get the new glass from and what model it is. I am new to fixing my phone and the insurance company tried to get a $165 from me for this like a need a replacement phone. This phone is not a month old for me to get an used phone from them.
由完成的
I have the same problem. I've had this phone for 2 weeks and the INS CO wants me to pay $225.
由完成的
添加一条评论
最有帮助的答案
those are just on there with an adhesive, heat and pick it off. be careful to not damage the bezel if you don't want to replace that as well. Don't let your tool knick the camera lens or you'll have focusing problems afterwards. be sure and use a quality adhesive to put the new one back on and you're good to go. I don't know if an s6 lens will fit or not, but if it fits-it ships. you're good to go, theres nothing special about them.
这个答案有帮助吗?
得分 5
2条评论:
First, thanks for the excellent advice. The s6 lens works as a good stopgap, but it doesn't fit perfectly (slightly too small).
由完成的
Bobby, quick question. What kind of adhesive is safe to use to put a new glass on? I found lens cover kits on AliExpress, but do not want to open up the phone, would rather replace glass only.
由完成的
添加一条评论
添加你的答案
Stephen Hricko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 24
总计 19,199
