跳转到主内容
加入维修社区 - 创建账户
Super Nintendo Entertainment System (SNES),或简称为 Super Nintendo,是任天堂于 1990 年发布的一款 16 位游戏主机。Super Nintendo 是当时最畅销的产品之一,至今仍拥有庞大的粉丝群。
Why does my game freeze while playing?
As I am playing Donkey Kong 2, Kong or one of the other characters will stop moving regardless of the buttons I press.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Do NOT blow on your old carts. The moisture from your saliva CAUSES the oxidization of the cartridge contacts. I generally use a q-tip and some low percentage isopropyl rubbing alcohol to clean contacts. Just dip the q-tip in the alcohol and dab off the excess on a paper towel and rub it along the contacts in the cart. Then used some canned air duster and the other side of the q-tip to dry it off.
If you want to clean the socket in the SNES, you can either buy one of those foam slot cleaners that they used to sell for that express purpose, or what I use is a butter knife and a clean tshirt. Dip a little isopropyl on the tshirt corner, you just want it damp so you don't drip into the socket. and then wrap the shirt edge around the knife and push it into the slot. don't force it too much because you don't want to bend the pins, but it should slide in and out fairly easy. I got a lot of grime out of my SNES slot the first time I did this. Then blow some air duster in there to make sure it's all dried out before you plug it back in and turn it on.
这个答案有帮助吗?
得分 5
2条评论:
There is not enough moisture in your breath to oxidize the copper contacts of a pin unless you do it for hours every day, for years. Also DO NOT put alcohol in the contacts. If you want to clean the pins of a system, use packing tape or a coffee filter and a smooth credit card to lift dirt out. Alcohol only rubs the dirt in further. This is why you are supposed to use an eraser on the copper contacts of the game when cleaning them, rather than alcohol. Please do not post things without doing research first.
完成的
Android, take your own advice (about research first). Iso-propyl and Brasso derivatives will not add undue degradation to copper pins if used appropriately. Rubber erasers and packing tape however WILL cause sites for water vapor nucleation that can lead to copper oxidation and other ill effects.
完成的
添加一条评论
The classic answer to this is to blow in the cart where it goes in the console. This is good practice for cart-based systems, I suppose, it does the trick with the N64. If this doesn't work, the contacts on the cart might be particularly oxidized/dirty, try going at it with a toothbrush and some contact cleaner. Avoid getting too much contact cleaner on anything plastic, as most contain acetone and will warp plastics.
E: Huh, didn't know that, Andrew. I though the moisture increased the conductivity of the pins. Never thought of it in terms of oxidation...maybe I can get some alcohol in a spray bottle and some paper towels for my cart systems instead of blowing in them. Thanks for the tip, I guess.
这个答案有帮助吗?
得分 1
添加一条评论
sometimes the awnser is more difficult. Repairing the Super Nintendo i encountered several problems of which bad capacitors and a corroded reset switch are most common.
The caps used in the 90's aren't the best ever. Since you can't look underneath them you need to 'wiggle' the cap to see if it is loose. If so the legs could be corroded. but, there are only a fev capacitors on the board so i say repace em all for a buck or 3 to be sure.
Second is the reset switch. Normally when you press it you short out two contacts. When the switch is corroded or broken, the swicht makes contact all the time and therefor it cant start because it is resetting all the time.
There are several other options but these are fairly easy to check.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carl Parker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 38
总计 20,788
