跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 个问题 查看全部
Power button pin out?
Hi,
In trying to replace the power button I delaminated one of the solder pads. It's not the ground side, it's the side that just goes to a buried via. Does anyone know where this connects - I'd like to bodge-wire something for now so I can at least get my data off the phone.
There's an image of the problem here : https://www.dropbox.com/s/dxhnafoavvm8k8...
Any ideas?
David
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
David Mills, check to see if this will help. Looks like it goes to R11010
这个答案有帮助吗?
得分 4
3条评论:
Thanks - just what I needed.
完成的
Thank you a lot! That was exactly the information I was looking for.
I had the same problem and now fixed it with a little wire bridge soldered between the resistor and the pin of the switch. I don't know how long it will last, but for it works :)
完成的
Thanks a million! You saved my N5!
完成的
添加一条评论
添加你的答案
David Mills 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,116
