跳转到主内容
加入维修社区 - 创建账户
这款白色耳机配备了遥控器和麦克风,随 Apple 音乐播放器和 iPhone 附赠。它也可以单独购买。于 2008 年 9 月 9 日发布。
How do I fix a broken volume button?
On the plastic piece on the cord of the right ear bud, there is the control piece that lets you control the volume and the play/pause. The button that turns the volume up is not working, so I need to either figure out a way to fix it, or at least remove the top part of the remote.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
I don't believe that you can fix the problem, likely a piece of dirt got into the volume control and is blocking the contacts however I don't believe the volume controls can be opened without destroying them all together.
It may still be possible to get them replaced by Apple, if the ipod you are using them with is still under warrantee (all new ipods come with a 1 year warrantee which will cover you'r ipod and the in-ear phones you'r using it with, however can be extended to two years by purchasing the applecare program) to check if the ipod is still under warrantee input you'r ipods serial number into this webpage https://selfsolve.apple.com/GetWarranty....
Hope this solves the problem!
这个答案有帮助吗?
得分 1
添加一条评论
Just go to android, iPhones are trash ^.^
这个答案有帮助吗?
得分 0
添加一条评论
Just get an android, iPhones are literal trash cans ^.^
这个答案有帮助吗?
得分 0
添加一条评论
i tried to open mine and then i found this site :( i broke my freaking earbuds
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John McWaters 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 26
总计 15,445
