Why wont windows 7 boot
i have a windows 10 laptop but i want to put on windows 7 because of opedit
i put it on a bootible drive but it keeps saying cannot find drivers even after i inserted them
Have you ever thought of just using a VM and installing windows 7 on that and running it from inside windows 10
这个答案有帮助吗?
editing programs are best to run in a virtual environment that way if you screw up you OS you can just reload and try again VM Ware is a good and easy to use Virtual Machine
i would like to use the parental controls on windows bc i dont have windows 10 pro
is the opedit a parental control program ? I thought you were talking about OP/edit. What version of windows 10 do you have
have you tried this
Hi from reading what you said it sounds like you are trying to install windows 7 onto a windows 10 PC, and that this PC has windows 10, well to use a boot media on windows 10 you will have to change the bios from UEFI to Legacy before you can boot to a media like a flash drive or DVD
这个答案有帮助吗?
How is that done?
i turned off secure boot and changed to legacy and it still didnt work
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 104
4条评论
Sorry. we cant understand what you want to do.
are you going to downgrade windows 10 to windows 7 or do you want to install component used on windows 7?
由 Buddhika Mahesh 完成的
and please tell us what Laptop you use and how you made the bottable USB-Stick (wich tool)
由 DonFibo 完成的
downgrade from windows 10
inspiron 14
由 dave 完成的
it was rufus
由 dave 完成的
