跳转到主内容
加入维修社区 - 创建账户
入门级平板电脑,配备 7.00 英寸 1280x800 显示屏,搭载 1.3GHz 处理器、1GB 运行内存和 500 万像素后置摄像头。
Startup loop won't stop
At first... It was shut down and restart when it connected to internet, and afterwards it gone in a startup loop to the logo and shutdown again.
I cannot stop it or complete start my tab.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
i have your problem in my tablet can i ask you how you fix it pleas
完成的
I have the same problem in my device. so far I can not solve this problem. if your problem was solved, please help me? thanks in advance.
完成的
添加一条评论
1个答案
最有帮助的答案
Try a hard reset. Here's a video on how to do it: https://www.youtube.com/watch?v=L2nFwCzf...
这个答案有帮助吗?
得分 2
3条评论:
i've tierd this and it faild "wipe data faild" error : connot get phone encrypt state"
i also tierd flash officail stock room but i couldn"t cuz it keep restarting (usb disconnect over and over) than tried to use adb to flash it but the "usb dubbing " wasn't actived
and no matter i try to installe rom (zip file) or any other package using recovery mode i get this" installation aborted"
完成的
If you encounter the mount /data error or error mounting data message in the recovery mode of your MTK Android (e.g Tecno, Gionee, Infinix, Opsson, Innjoo etc) phone then your /data or /SD card partitions might be corrupted. To fix this, try the methods below:
Format SD card (If there's a slot for it)
* Remove the SD card
* Format the memory card on a PC (FAT32)
* Slot the SD card back in and boot the phone normally
* Switch off then boot into recovery mode
* Re-try the operation
Wipe data & eMMC
* Boot into recovery mode (volume up + power) and select Wipe data / factory reset
* If the above fails, boot into Chinese factory mode (Volume down + power) and select the option with eMMC in its name
* Reboot the phone
完成的
thank you the quick answer but ....
there r no sd card on the phone just the internal storage 16GB i guess
pic : http://img15.hostingpics.net/pics/125395...
完成的
添加一条评论
添加你的答案
wello25 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 7,458
