跳转到主内容
加入维修社区 - 创建账户
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
I want to replace micro-usb
Hi all,
I have an issue when I plug usb cable on my device, battery doesn't charge. I don't see icon with storm inside. If I move the plug I see/doesn't see, icon with storm inside.
I think the problem is in the micro-usb.
If I replace the micro-usb/daughterboard, I must recalibrate something ? like is write on ASUS web site : http://www.asusparts.eu/en/Asus-90NK0080...
Thx for tour feedback
Sorry for my bad english
Vincent
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Vincenet PONS, not sure where the "re-calibration" fits in. I would suggest that you get the part from here. Take a look at the stories below the part description. It appears that calibration was never necessary for the successful completion of the repair.
Replace a corroded, damaged, or malfunctioning LCD daughter board containing the micro USB socket. This part is compatible with a model ME571K Nexus 7.图片
产品
Nexus 7 (2nd Gen Wi-Fi) LCD Board
$34.99
这个答案有帮助吗?
得分 1
2条评论:
Ok oldturkey03, thx for your answer.
I'll buy this spare part, and I hope, issue will be fixed.
完成的
I've done hundreds of this exact repair on this model tablet, I can confirm that OldTurkey is correct when he says there is no calibration needed (not even sure what that would mean in this circumstance).
完成的
添加一条评论
Hi Vincent,
you could try this:
The loss of connectivity may be caused by the build up of dust in the socket.
The good news is that it is very easy to clean the USB-socket. First remove the battery in order to avoid any short circuiting during the procedure. Then take a needle and pick out all dust and dirt from the USB socket. You'll be amazed how much will come out. A magnifying glass may be helpful. Once the socket is clean, reinstall the battery.
这个答案有帮助吗?
得分 0
3条评论:
Hi @sytsypytsy ,
Suggest that maybe a vacuum cleaner may be a better first option then if necessary try with a needle, although a wooden toothpick may be better as it saves taking out the battery. ;-)
完成的
Hi Jayeff,
Thanks for your comment. I wish i had a vacuum cleaner small enough to use in a micro USB, that would be awesome. Since the dust is pushed in many many times and thus compacted, it is often too solid to pick out with a wooden tooth pick. Nevertheless your idea is worth trying. Thanks again
完成的
Hi @sytsypytsy ,
I just use the tapered nozzle that is usually provided with most vacuums. It mostly does the job as it covers the whole port
完成的
添加一条评论
添加你的答案
Vincent PONS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 317
