跳转到主内容
加入维修社区 - 创建账户
第一代 Legacy 于 1989 年 2 月 1 日在日本经销商处发售,并于 1990 年开始在全球分销。
Front left Headlight dull
Subaru 94 rs legacy. front drivers lights are dull I've taken the bulbs out of the case and turned them on but the drivers side light is dull and orange on hi lo and dip what could it be. Do you know where the earth is for the drivers side headlights?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would test for a bad ground by putting a jumper wire between ground on the vehicle, and the ground for the bulb, and seeing if that increased the brightness. I believe your car uses an H4 type bulb with a 3 prong base. If you hold the bulb so you are viewing it from the back, with the middle prong at the top, the prong on the left is ground, the middle is low, and the right is high beam.
这个答案有帮助吗?
得分 3
1条评论:
Bulb might be dying. +
由完成的
添加一条评论
添加你的答案
brandon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 35
总计 3,026
