跳转到主内容
The Motorola Droid X is a smartphone manufactured by Motorola Mobility, Inc. that runs the Android 2.3 software.
Why does my phone say invalid battery and not charging
droid x battery not charging and has question mark inside battery icon
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
Zccsalter, could be caused by a bad battery. Consider changing it. Try to remove the battery and keep it out for while then reinsert and see if that helps. You could also try a hard reset (carefully because you may lose your files). It may be because the battery is discharged beyond its threshold and does not take a charge. Once that happens, your phone does not get the right information (proper voltage is part of the signature information) from the (smart battery)it declares it as "invalid" and will not charge it. For that you could try to charge the battery on an aftermarket charger outside the phone for a few hours.
这个答案有帮助吗?
得分 2
4条评论:
sorry it doesn't work for me. I bought my phone few days ago. when its battery under 15% phone automatically turn off & then show invalid battery when i want to switch on my phone.
Is there any software problem or something else?
完成的
This is a replacement battery I bought that is doing this. I did request from the seller to send me another because this one was indicating invalid battery and the second one says the same thing. Both batteries came at a 50% charge on them. I do not have an aftermarket charger for this kind of battery. What ti do then?
完成的
This is the old phone, but I have a I that’s from the company but it still says a valid battery battery
完成的
What should I do about it?
完成的
添加一条评论
添加你的答案
zccsalter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 14,967
