跳转到主内容
The Garmin Nuvi 200 is part of Garmin's 200 series of GPS navigators. It was released in May of 2007. It comes with preloaded maps of the entire continental U.S., Hawaii, and Puerto Rico. It is available in classic silver or pink.
12 个问题 查看全部
nuvi 200 stopped locating satellites.
Worked fine, then: searching for satellites forever. Everything else is working. Updated software, chipset, downloaded new maps, reset it dozen times, put it outside away from buildings for a day and it is still somewhere in Kansas.
Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I noticed you never got an answer to this. Are you still having this problem
完成的
添加一条评论
2个答案
已选择的解决方案
Why not try this. Perform an update using Garmin's WebUpdater. Update to the newest version and also update the "Chipset M" which can be selected as an additional update after the firmware has finished updating. Then perform a master reset using the button on the back of the unit with the unit turned on. Garmin Updater and Garmin's solution Since you are not in Kansas anymore, you have really nothing to lose....good luck
这个答案有帮助吗?
得分 2
添加一条评论
Borré de manera erronea los mapas que venian originalmente con mi Nuvi 200w y ahora no sé como restaurarlos, me ayudan?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eurocloset 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 11,888
