跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
iPhone won't turn on
Recognized in itune but can't restore. The screen is always blank.
Shouldn't be problem with itune since I tried in serveral computers. Shouldn't be issue with the screen either. All come back with error 1601.
Probably hardware issue. Any suggestions on how to fix it ?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
Error 1601 means the device won't come out of DFU mode into recovery mode; it's probably a bad logic board. (The screen will never light up in DFU mode.)
The logic board is the most expensive part of the phone to replace; you're probably better off selling this one for parts and buying a used (working) phone on eBay.
这个答案有帮助吗?
得分 1
1条评论:
+ nice to have someone around who really knows this stuff
完成的
添加一条评论
Apple disagrees with it not being iTunes' fault. What happened to the phone leading up to this problem? How did you rule out the screen?
这个答案有帮助吗?
得分 0
1条评论:
I tried with another working screen and same thing happened...thus I ruled out the screen
完成的
添加一条评论
Hi
Disasembly your iphone and disconect the LCD flex and plug again.
Sometimes there is a false contact.
If dont works the LCD is damaged try to replace.
这个答案有帮助吗?
得分 0
1条评论:
for some reason, the screen is always blank even Itune recognize the phone in DFU mode. I tried an LCD from a working phone and it still acts the same way.
完成的
添加一条评论
for itunes fault codes http://support.apple.com/kb/TS1275.
Update
Error 1603: If you receive this error and the iOS device is not automatically placed into recovery mode, it may be necessary to do so manually. Refer to iPhone and iPod touch: Unable to restore for steps on placing iPhone into forced recovery mode. Also, remove the IPSW and attempt to restore again. If you do not want to remove the IPSW in the original user, try restoring in a new administrator user.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
momocha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,624
