bent , cracked screen
My iphone 6 plus was bent and the screen was cracked. It wouldnt turn on but it does connect to itunes. Does that mean that the logic board is Usable? I plan to salvage and transport the parts to a new housing.
Cheers
Sam, hard to say since we cannot see the damage. You definitely want to replace the display and the battery. While you do that, inspect the rest of your parts carefully. After you use a new case and transplant your parts re-evaluate. Here are all the guides you need to work on your phone.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,739
1条评论
I meant to say i would change the screen, housing and battery if needed. All i need to know if the logic board is fine if it connects to itunes , cause it is troublesome to find a replacement.
由 Sam 完成的
