跳转到主内容
24英寸显示器,内置iSight 摄像头,麦克风和扬声器。 1920*1200分辨率。 发布于2008年10月 型号为A1267
84 个问题 查看全部
Common Logic board burn spot?
Hello
My cinema display started smelling weird and then shut down. I opened it and found the problem to be a burned spot on the logic board. No problem I'll just replace the logic board and then I can use it again.
So I was browsing for a new board when I saw a dutch thread with someones logic board also burned. But the weird thing is that the burn is at the exact same place.
Does anyone have had a problem with a burned board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论:
Lukas Guy, it might help if you add some images to your question. That will allow everybody to see where the board gets damaged
完成的
Hi Lukas Guy, I have a Apple Cinema with probably the same issue. How did you replace this part? Where can i buy this part?
Gr. Vincent (from Holland as well)
完成的
添加一条评论
1个答案
Lukas Guy, that looks like the LED driver. It is most likely a "common" failure if you have a short within the backlight circuitry. Any short there would take out that driver. I would suspect the primary offender would be the LCD connector.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lukas Guy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 2,466
