跳转到主内容
加入维修社区 - 创建账户
三洋电视的维修指南与支持。
volume will not work with remote.
Volume can not be controlled with remote. Have to push the buttons manually
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
5条评论
All the buttons on the remote work. I did change the batteries.
The volume bar on television only show when the volume buttons are pushed manually, not when you push the volume button on remote.
完成的
My Sanyo control volume does not work to turn volume down
完成的
The vol go up and down by itself
完成的
Why my 32 inch Sanyo go up and down by itself
完成的
Volume goes down by itself
完成的
添加一条评论
4个答案
最有帮助的答案
Are any of the other buttons working on the remote? Can you change channels or power it off or on?
If only the volume buttons are not working it is likely a problem with the remote control.
First of all, I would replace the batteries in the remote. If the batteries are getting low sometimes they can do flaky things. There may be enough power to make some things work(like power button) and not others (like volume button). Also make sure there is not corrosion in the battery compartment on the battery terminals. Old batteries can cause corrosion and make the batteries not have good contact and not supply adequate power.
If that doesn't work, I would purchase a universal remote and test it. If you did not want to buy a new device, some of the newer Samsung phones have Infrared blasters that allow you to use them as remote controls. You can download free remote control apps.
If a different remote doesn't work. The problem would be in the tv. If that is the case, perhaps someone else here with mnore knowledge than me.could assist with the actual tv repair.
这个答案有帮助吗?
得分 2
8条评论:
I can not turn the volume down manually. I replace the remote but still doesn't work what could be the problem
完成的
My name is LaVerne and I have not been able to adjust the sound with the remote nor manually on certain movies. It is either too low or too high and I am unable to change it.
完成的
There is nothing wrong with the batteries and yes all the other buttons work
完成的
It has to be the tv that has the problem
完成的
My tv is a 40” Sanyo
完成的
显示更多的3条评论
添加一条评论
Does a small panel appear on top right screen saying INPUT and HD . Reset the TV buy unplugging it for a few seconds, then plugging it back in. Fixed my problem..
这个答案有帮助吗?
得分 0
添加一条评论
Go to the TV settings and change the Remote adaptivity. Keep the Remote on sunlight for 30 minutes this boost the battery power.
这个答案有帮助吗?
得分 0
添加一条评论
This sounds silly but mine wasn’t working because if you have tooo many thing on top were the señsor is it can’t read it take of all the junk you have on the table or where it’s located and it should work now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 13,233
