跳转到主内容
加入维修社区 - 创建账户
第四代 Volkswagen Jetta,也称为 MK4 或 Bora,是 Volkswagen 的家用轿车。
not shifting into overdrive
two things i would like to know the location of my tcm trans control modular in my 1999 vw jetta 2.0 newer body style. and why do you think the trans is not shifting into overdrive what should i look for mick
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
I have a 2002 Jetta 2.0 that wouldn't shift into overdrive. We changed a speed shift sensor, it didn't fix it. Come to find out, there's a speed shift sensor on top of the transmission under the transmission mount. It has a cord with a plug in attached to it, where as the other speed shift sensors don't have a cord connected to them. This fixes it. You also have to reset the transmission computer afterwards. So to do that turn the key in the on position without starting the car. Then hold down the gas petal for 30 seconds. That's it, good it go!!
这个答案有帮助吗?
得分 2
1条评论:
Is it necessary to have a speed shift sensor for overdrive in the Jetta?
完成的
添加一条评论
The TCM is below the wiper cowl along with the ECM. It might be low on ATF, which would prevent it from shifting into overdrive.
这个答案有帮助吗?
得分 0
1条评论:
As far as I know it has a sealed transmission.
完成的
添加一条评论
Because attacks 5 and 1/2 Grand at because I have to drive it up to 40 miles an hour to get it to shift out of second and then I can put it up to 80 miles an hour and it won't shift again and I'm tacking 5 1/2 Grand
这个答案有帮助吗?
得分 0
添加一条评论
i change the body valve whit at new wire conector and transs dont shift gears please helpme
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RADIOFLYER 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 23
总计 16,174
