跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 个问题 查看全部
How do I remove a smashed screen with a suction cup?
I have a very smashed up front panel on my iphone 3gs and I am wondering, if I order the front panel replacement, wont I have trouble pulling the screen out in step two using the suction cup because it is so smashed up and air will get through the cracks in the smash and break the seal on the suction cup. Sorry, that was worded really awkwardly. I am sure there must be a way to do it because why else would you replace the front panel (ie. unless it was all smashed up)
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
I would use clear packing tape and cover the whole screen (one piece should do it). Then use another piece of tape (making a tab) using it as the suction cup
Edited to add:
I know its an old topic but it might help others with the same issue :-)
这个答案有帮助吗?
得分 5
4条评论:
+ good thinking
完成的
+ works well
完成的
+ yup, or double-sided tape ... or, !&*!, glue something onto the front panel if you're throwing it away anyway.
完成的
Sweet! Thank you!!!
完成的
添加一条评论
i would not use the suction cup method for that - i use the small blade of my victor inox sd knife. it's small enough to use it as a lever. but you can use any pocket knive with a small blade, the best point to use it as a lever is in the middle area, near the home button.
这个答案有帮助吗?
得分 2
1条评论:
Thank you Markus Weiher, it worked
完成的
添加一条评论
Best tool for that is iSesamo.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MadameBiatch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 9,197
