跳转到主内容
加入维修社区 - 创建账户
适用于第一代 Apple iPad (Wi-Fi 版) 的维修指南、拆解和故障排除信息,提供 16、32 或 64 GB 存储容量版本。于 2010 年 4 月发布。型号为 A1219。维修过程简单且不需要加热。
unknown error occured 1671
cant open or close ipad
回答此问题 我也有这个问题
这是一个好问题吗?
得分 15
1条评论
1. Update iTunes to the latest version to ensure that it is compatible with the version of IOS and the iDevice with which we are working.
2. Update the antivirus and run a full system scan for infections.
3. Install the latest version of the computer operating system.
4. Connect the iPhone or iPod Touch to a high-speed USB port (USB 2.0 or higher).
5. How to Solve an Unknown Error 1671 Occurred on iPad
由完成的
添加一条评论
6个答案
最有帮助的答案
iphone itunes error 1671
这个答案有帮助吗?
得分 2
添加一条评论
non riesco ad usare i pad
这个答案有帮助吗?
得分 1
2条评论:
my ipad was not restore and not updating
it's showing the only showing itunes simble
由完成的
my ipad showing the an error occurred 1671
由完成的
添加一条评论
did this error occur during a update?
try
Resolve iOS update and restore errors in iTunes
Resolve issues with an over-the-air iOS update
这个答案有帮助吗?
得分 0
6条评论:
no
flickered and went to iTunes logo with charging pix
由完成的
wont turn on or off tried the iTunes restore
由完成的
So you see the itunes logo on the ipad and when connected it and tried to restore it you got 1671?
Try to restore the ipad in DFU Mode:
Step 1: Turn off your iPod touch / iPhone completely and connect to PC / mac
Step 2: Hold down the Power button for 3 seconds
Step 3: Without releasing the power button, also hold the Home button for 10 seconds
Step 4: Without releasing the home button, release the power button and keep holding the Home button for 20 seconds.
由完成的
Sometimes you need to update or restore your iOS device and for this purpose you use iTunes applications. To transfer, restore, update iOS devices you simply need to connect your device to computer using USB cable and while going through some of the above activities it shows iTunes error 1671. It generally happens due to incompatible version of the iTunes or iTunes components are corrupt or damaged USB cable.
http://www.iosdevicerecovery.info/blog/c...
由完成的
Johnny Martini - Thank you. The following fixed the 1671 error for my iPad.
由完成的
显示更多的1条评论
添加一条评论
none of these ideas work
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issues and it ended up being iTunes was still downloading software for the update. I don't have a clue why it prompted me to continue the update when it was still downloading. Look in the upper right-hand side of iTunes for the square box which has the downloading indicator on it. Make sure it's still not downloading before reacting to the prompts. Once it was done, I was clear for takeoff! Hope this helps some of you.
这个答案有帮助吗?
得分 0
添加一条评论
John martini's workflow solved my problem: apple 0: ifixit: 1 yay
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
casinorat1968 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 48,755
