跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
319 个问题 查看全部
How do I fix an E1 error message
Have a Kenmore Elite HE3 electric dryer that intermittently gives me a E1 error message. The dryer restarts with no problem once I cancel and reset the drying cycle. Dryer heats up and the motor turns the drum with not issues.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Dewayne, the E1 error code indicates that there is an open thermistor which is used as a temperature sensor. Since you can not fix those, you will have to replace it. Of course, bad wiring between the thermistor and control board could, as well as a failed control board can also cause this error. Start by replacing the thermistor. You can get the part from here.
You need "take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #32 screws, and remove the #2 screw at the very bottom of the duct assembly with a bracket#11 attached to it, remove that one also. Unplug your dryer first! Then your thermistor is #42 on the blower housing, next to your thermal fuse#59. "
from here.
这个答案有帮助吗?
得分 0
添加一条评论
Due to the fact that over 4000 people have inquired about the E1 error , I'm sure that the thermistor is what is causing my dryer to stop . Does anyone know if Kenmore is doing anything for their customers, on this subject ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dewayne 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 101
总计 9,051
