跳转到主内容
加入维修社区 - 创建账户
适用于数百种光盘驱动器的维修和拆卸指南。
disk not being recognized and no indication
the drive is not recognizing when a disk is inserted and the disk gets ejected bak why?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
it sounds like a dirty lens - most "faulty" optical drives have only a good amount of burned in dust on the lens.
there are many ways to clean the lens - i would do it like the autor of the article - since it's the way to get it really clean
you can read about the different cleaning methoths here: CLICK
good luck
这个答案有帮助吗?
得分 2
添加一条评论
Is this only occuring with one disk or have you tried many different disks? A simple reason that first comes to mind is that your disk is scratched. The more complicated one would be that your optical drive is broken. This is actually a very common problem. There are a lot of guides on iFixit that will show you how to replace it. Good luck!!!
这个答案有帮助吗?
得分 0
添加一条评论
Have a look at this answer. The first answer is also a possibility, but if that doesn't help, follow the suggestions on the link I provided.
这个答案有帮助吗?
得分 0
添加一条评论
we tried with , three disks and they are all very good disks,new (2) and old (1) and no scratches
out of three disks one started working.rest two did not work.
again inserted the working disk again. but this time that also did not work and got ejected.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
srinivasan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 15,607
