跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
问题已关闭
Computer is not turning on, might have fried the logic board
Hello
My Macbook Pro 15" 2,2 GHz i7, from 2011, needed some repairs. So I decided to take it apart to have a look at the inside.
But, things didn't go so well. I used what I thought was a spudger, even though I new it wasn't a spudger, but a metal thing.
It gave a spark, smoked a bit, smelled a bit burnt and after that I could turn it on.
So, do you think I fried to the logicboard? Or could it be something else?
I know how stupid I was, so don't tell me!
Thanks, and good day!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
How about posting a couple of images of your board to may be identify what you shorted out? 在已经存在的问题里加入图片
完成的
添加一条评论
3个答案
已选择的解决方案
If it ain't broke, don't fix it!
Si fractum non sit, noli id reficere!
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Can you see any where on the main board that looks burnt? Look at the little board in the corner where the charger plugs in. What does it look like? If it's just the little corner board then you may be okay. If it shorted the main board you may be borked.
这个答案有帮助吗?
得分 2
添加一条评论
you shorted something for either a low voltage S0 rail for a large chip which is made to power low impedance loads, or PP3V3 which is a resilient rail. You're lucky it wasn't a 5v or 12v power rail or you would have been &&^&@@.
This is an 820-2915 board so it will be fried soon enough anyway without any of your intervention.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 304
