跳转到主内容
加入维修社区 - 创建账户
Kindle Fire,也称 Fire 或 Amazon Fire,是 Amazon 推出的平板电脑。操作系统基于 Android,使用多点触控屏幕。拆卸维修仅需用到螺丝刀和撬棒。
touch screen does not respond
Why does my touch screen not respond every time I touch it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
My screen has only 1 area where it doesn't responde
完成的
Mine similar issue just touchscreen buttons on bottom that make it so I can switch apps
完成的
Same issue. Amazon hopefully will send a replacement. Switch to Samsung.
完成的
Help my kindle fire hd won't touch anymore and it's touch screen
完成的
My toch screen is frozen with a yellow line around
完成的
添加一条评论
1个答案
最有帮助的答案
mikecornerstone, could be a bad digitizer. Of course, you do want to try a soft reset first Soft Reset:
Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
Your reboot screen should appear when you release the power switch.
Wait a minute or two to give your device time to reboot
Turn the Kindle back on.
After that you most likely will have to replace the digitizer. Here is the guide for it
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mikecornerstone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 21,108
