跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
Missing capacitor needs to be replaced
Hello my name is Sgt John P. Sunga - USMC. I recently acquired an early 2009 MacBook Pro 17". It was not booting up. After breakdown and cleanup and applying new thermal paste, I discovered one side of a tiny small capacitor broken off. When lined up proper, it boots up and everything works great. The caps was just barely hanging on and finally broke off. There are no markings on the caps but I took a picture of Where it is located. If anyone out there knows what type of cap and where to get it, that would be greatly appreciated.
Thanks,
John
https://www.dropbox.com/sh/ma1d85a1p0d36...
The cap is located on the immediate left of resistor R7120. Below the missing cap looks like two identical caps that are mounted vertically.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
SgtJohnPSunga, thank you. The part that is missing is C7196 which is a 0.1UF 16V 10% capacitor in a 402 package. Available right here as well as many other places.
Update 09/03/2015
Location of C7771
这个答案有帮助吗?
得分 1
2条评论:
C7771 is a 330UF 2.0V 20% Poly Tant capacitor in a B2 case. Available right here as well as many other places.
完成的
Thanks so much.m I didn't expect an a response this quickly, this really helps me out. Thanks again.
完成的
添加一条评论
最有帮助的答案
While this is open, since you are already soldering, replace C7771. Its time to die is coming.
这个答案有帮助吗?
得分 2
2条评论:
I'll go ahead and replace this as well. Is this the same cap?
完成的
Where is the C7771 located?
完成的
添加一条评论
添加你的答案
SgtJohnPSunga 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 2,798
