Tablet wont charge or come on
The tablet wont charge or turn on at all. The screen is totally black and this is the second one that I purchased and it has some kind of problem with it. It was 80.00 wasted. What can be done about it?
Sharon Withrow, start with a new cable and an AC charger. then check the micro connector to make sure that the cable fits properly. If that does not do anything, replace the battery and double check your power adapter. Make sure it is still properly mounted to the board. If that does not work, you most likely are having logic board issues. If under warranty, replace it. Use these guides to work on your tablet.
这个答案有帮助吗?
but seriously, its getting power as the red light goes on so dont try to say its the charger. and do they even sell the batteries as they are wafer ones glued inside the tabet
Denver J. Yorton, CPhT Seriously! You obviously have not read the original question! Yes, they do make batteries for that one as well.
I bought mine brand new when the battery died never came back on nor will it charge at all. Tried several different chargers and cords still nothing but a 100.hole in my pocket. Don't know where to send it or should I just beat it with a hammer
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 45
总计 6,437
2条评论
this is also my second nextbook had a problem with screen not coming on with other one sent back this was a replacement. getting tired of them not working !!!
由 kathy mcdaniel 完成的
由 Daniel G Pou Gonzalez 完成的
