跳转到主内容
Repair and disassembly guides for projectors.
temp and lamp lights flashing
temp and lamp flashing lights on Epson 3010 projector
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Johnny Saltos,most common cause for that is a bad air filter. I'd start by replacing it
这个答案有帮助吗?
得分 5
2条评论:
new filter,problem still
完成的
lemp red signal
完成的
添加一条评论
If the filters new and the Fans are running at the normal speed , then its most likely ur ma inboard that needs replacement!
We have had a few of these units come with the mainboard problem!
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
hey might there be fraudulent procedure in this?
my lamp was working just fine one day until this epson started complaining about how many hours Ive had it (3984 hrs). Now when I turn it on, it shines brilliantly for one minute, then the dumb projector shuts it off and has the lamp error light flash red.
This seems like a ploy to get me to spend money.
I even read somewhere that certain projectors send a signal to burn out a circuit on the lamp on purpose.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
hi i have epson modle number is>>>>>( HC=8350 - TEMP &LAMP LIGHT IS BLINGKING ??????
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Johnny Saltos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 68
总计 2,767
