跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
Time to replace the Thermal Paste?
I've had my MacBook 2.26 GHz Core 2 Duo (13-inch Late 2009) MC207LL/A MacBook 6,1 - A1342 for going on three years this December, I bought it used through eBay and it's been running great after numerous upgrades / replaced parts including the Cooling Fan so I know that's not an issue.
I've Googled what the normal operating temperature should be and it seems to be in the normal range but suddenly the range keeps changing from 104° F to 122° F ( CPU die ) with the exhaust fan running at 6200 RPM + - ( smcFanControl ) but not holding steady or dropping below that range. ( Battery power )
Same readings with iStat Menus -
The only app running right now is Safari and CPU usage is not abnormal , Background processes aren't out of bounds.
Sensors check out, Could it be time to replace the Thermal Paste on the heatsink ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Make sure your fan vents are clean.
Here's how to get to the heat sink: MacBook Unibody Model A1342 Heat Sink Replacement
Here's a guide on replacing thermal paste: 如何涂散热膏
Here's where to get the thermal paste: [关联产品丢失或禁用: IF179-010]
Electronics Skills图片
指南
如何涂散热膏
难度:
中等
5 - 20 minutes
MacBook Unibody Model A1342 Heat Sink图片
指南
难度:
困难
15 - 30 minutes
这个答案有帮助吗?
得分 2
添加一条评论
If the cooling fan is running then i would try and replace the thermal past just to see if that fixes the issue it it does not then the issue is something else. It is always best to start cheap then work your way up when fixing issues.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Bell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,067
