跳转到主内容
加入维修社区 - 创建账户
Turtle Beach Ear Force XO Seven,于 2013 年夏季发布。型号:TB300-2219-01。兼容 Xbox One 和移动平台。拆解这款耳机相对简单,初学者应该不会遇到任何问题。
How can I stop right side creaking
Is there a quick and easy solution to stopping the right side rotator of the headset from creaking? The persistent creak is near unbearable, yet the left side in silent. Is there anything that I can spray in the joint or something because I'm just about ready to go buy a new headset.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
anyone come with a solution to this problem??
Thanks.
由完成的
i fixed mine buy getting a set of hyperx core. i will never own turtle beach again
由完成的
添加一条评论
1个答案
最有帮助的答案
my XO seven was making a lot of noice in all the movable joints , i used wd 40 to lubricate the joins.
do 1 joint at the time , spray the joint , have a rag or paper towel to whipe of the any spills , move the joint and keep whiping , move on to the next , after all joints are done make shure there is no spills .
this will remove most creaking and noices from the joints.
这个答案有帮助吗?
得分 2
2条评论:
You lovely being. I didn't even think of WD40, I used oil first. Which didn't work at all. I bought the Arctis Pro Gamedac a couple of days ago and of course I was pretty !#^&@@ when my 230€ headset started creaking all of a sudden.
WD40 fixed it. I had totally forgotten about having that stuff. Thanks a ton !
由完成的
Hey Mike, I’m having the same issue with my headset. The hinge that connects the ear muff makes a creaking sound and there’s another lil hinge that is connected so you can rotate the ear muff up and down and the other hinge you can move side to side so they can lay flat if they are resting around your neck. How long did the WD-40 trick last for?. Thanks for the help.
由完成的
添加一条评论
添加你的答案
Troy Schuster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 6,183
